Elevation way off
blp
Elevation way off
Post by blp »
I set the elevation prior to a ride, 95m. Most of the ride is slightly above sea level, about 3-5 meters. However, the elevation in Issac shows the sea level elevation as 25 - 50m! Way off. The incorrect elevation occurs regardless if I set the elevation on the Newton prior to the ride, or in Isaac after the ride. Is there something I missed in the initial setup of the Newton?
iBike_2012_09_23_1101_61_km.ibr
(652.77 KiB) Downloaded 501 times
Re: Elevation way off
It looks like the Newton's baro sensor is reading elevation very consistently.
One of these things is going on:
1) your baro sensor is not working correctly
2) your starting reference elevation is incorrect
3) you're riding riding at more than 3-5 meters above sea level
I cannot tell which of the above is true. I do know that we have had zero problems with baro sensors, so far...
A friend of mine starts nearly every ride by doing a sudden drop to sea level and he sees the same thing. Fortunately this doesn't affect wattage.
For me living near the ocean, I also tend to see things like this. I think part of it is due to the sudden barometric changes that can occur when right at the water's doorstep, though I don't know how far you are from the ocean.
blp
Post by blp »
Thanks for your observtions.
I live in Vancouver, BC and am about 10 minutes to the ocean. I use the elevation from a land surve document I have for my house, so I know it's accurate. I also know that my feet aren't wet when I ride at the shore's edge, but I'm not 25m (80 feet) above the water either.
I realize it doesn't affect wattage, but it might affect total climb and other metrics over a ride. A little annoying for a geek.
