Analyze Route and Analyze Tilt Advanced View
texmurphy
Post by texmurphy »
Often when I do the Analyze Tilt and Power Advanced View, the Before Repair shows a lot of drift from zero. Especially after significant climbs and descents. Today's ride is exceptional for odd repair, both before and after. For several minutes on this ride we were near sea level, which recorded as negative on the Newton+ due to barometric weather changes. Otherwise elevation was better than my Edge 500 (both set for known elevation at start).
ibr attached.
iBike_2012_08_21_0838_69_Miles.ibr
(1.52 MiB) Downloaded 444 times
Re: Analyze Route and Analyze Tilt Advanced View
Sometimes I worry we make things worse with all of the information we provide.
Please note that, after applying the changes, the results change by only 3 watts! This is an insignificant correction, about 2%...
We don't show the tilt plot as a matter of practice, because the Newton firmware does such a good job of fixing things in real time. If you want to look anyhow, go ahead :-)
texmurphy
Post by texmurphy »
Usually the correction in elevation matches "reality" in the Tilt Advanced View.
For today's ride, the entire elevation in the Tilt Advanced View is shifted negative in the image above.
A more normal Tilt Advanced View shows corrected tilt with normal elevation like below:
Same comment. There is negligible shift in the before/after stuff; about a 2% change.
Don't worry about dancing on the head of a pin... :-)
texmurphy
Post by texmurphy »
The question is if there is a bug in the chart display resulting in the totally negative elevation traces in the charts.
Question was not about the power calculation or dance locations.
KenS
Post by KenS »
texmurphy wrote:The question is if there is a bug in the chart display resulting in the totally negative elevation traces in the charts.
Isn't that just an error on the starting elevation?
The Newton only measures the relative changes in elevation, not the absolute elevation.
-- Ken
texmurphy
Post by texmurphy »
KenS wrote:Isn't that just an error on the starting elevation?
No, initial elevation set at ride start to reference elevation. The other elevation charts show elevation correctly, only Tilt Advanced View is wrong.
Try download of the ibr and see for yourself.
