Strava upload issues
nilbike
Post by nilbike » Fri Jul 27, 2012 11:10 pm
I have not been able to upload anything to Strava the last few days from the PowerHouse app.
Anyone else with the same problem ?
nilbike
Re: Strava upload issues
Post by nilbike » Fri Jul 27, 2012 11:18 pm
I'll reply to my own question...
Issue resolved by logging out and back in.
FelicianoVASA
Post by FelicianoVASA » Mon Feb 18, 2013 3:25 pm
I have the same problem. I try several times and the bug is still there...Help please
TriBike
Post by TriBike » Tue Feb 19, 2013 11:49 am
Make sure that you are logged into Strava from the PowerHouse app. Go into the Settings of the PowerHouse app, and scroll down to Strava.
Post by Velocomp » Tue Feb 19, 2013 12:52 pm
There is a bug in the PH app that shows itself if you log in to Strava from any other device (computer, iPad etc). After logging in elsewhere, you can't upload rides from the PH app unless you log-in again to Strava from the PH app.
We will fix the bug so that continual log-ins won't be necessary.
FelicianoVASA
Post by FelicianoVASA » Fri Mar 08, 2013 5:06 am
Hello,
I have done all the recomendation a still have the problem: "unable to upload your workout to strava"
FelicianoVASA
Post by FelicianoVASA » Thu May 16, 2013 5:44 pm
Have already fix the bug? I hope that you have developments soon.
FirmwareGuy
Post by FirmwareGuy » Fri May 17, 2013 7:45 am
It is not clear from your post that you've tried the "logout" and log back in workaround for this issue. Did you go back to the settings in the powerhouse app, select Strava, click on the "Logout" button, then log back into Strava using your username and password? Was the login successful?
Once you have a successful login, you should be able to upload your workout data to Strava.
FelicianoVASA
Post by FelicianoVASA » Sat May 18, 2013 2:38 pm
FirmwareGuy wrote:It is not clear from your post that you've tried the "logout" and log back in workaround for this issue. Did you go back to the settings in the powerhouse app, select Strava, click on the "Logout" button, then log back into Strava using your username and password? Was the login successful?
Thank you. I have done all that. The bug persists
FelicianoVASA
Post by FelicianoVASA » Tue May 21, 2013 6:42 am
No one from Velocomp can help me?
FelicianoVASA
Post by FelicianoVASA » Mon Oct 28, 2013 3:43 am
Dear Velocomp Sirs,
I have change iphone so there is no problem at that level, but I am unable to upload to Strava the exercices in the trainer on mode. Help please!
Why no one pay attention to my messages?
