I've noticed while out riding on a windy day that when my speed drops below 8 km/h (i.e. 5 mph) the Wind reading on the environment screen promptly drops to 0.0
But in the ride file the wind still seems to be recorded properly.
Just curious as I was thinking it would be nice to be able to work out just how hard the wind was blowing by standing still and pointing the bike into it
Wind display
Wind display
-- Ken
Re: Wind display
Measuring light wind speeds at rest is a very difficult thing to do. It's like watching a candle flame dart about and guessing how hard the puff of wind is.
We have intentionally disabled wind speed readings when bike speed is less than 5 mph.
still-chasing
Re: Wind display
Side note:
Trying to find the topic about "Analyze wind". if someone can re-direct please so I can better understand this feature. Thanks.
Re: Wind display
Yesterday was hot, nearby airport weather station recorded 92F peak on hourly readings at about the time I had my problem arise. My Bontrager bike computer next to the iBike recorded as high as 96F in the sun.
The iBike Newton+ went suddenly, while riding, from normal wind to goofy, I will describe.
Unfortunately I did not notice until restarting riding after a break. The wind seemed high, then I noticed it was stuck. The wind cal screen would not respond and was continually showing about 65. I did a hard reset and everything except date and time returned to normal, after a quick wind cal.
In Issac, I now had two ride files due to the reset. I was able to select the bad section and correct the average wind to zero (which was probably a bit low but close enough) and then append the files together for a fairly good total total ride file.
I have no clue why unless temperature affected this. I do use the RWS which would allow the wind port sensor to rise to a higher than ambient temperature.
Anyhow I am wondering if the iBike FW could monitor for this condition and correct it on the fly? I am thinking to simply test that the wind has gone quite high and do a reset or whatever to that chip or whatever the hard reset does but only to that chip and then restore the wind cal value into it or the like for automatic recovery? --- Just wondering.
Re: Wind display
Thanks for the diagnosis, John. And today was hotter and it did ok.
Now this disturbs me a bit as the unit was at about 65% when I got it home to upload my data and to recharge. Also after the hard reset, the unit did well for the rest of a 40 mile ride (43km part 2 vs 18km part one that had the failure). Shouldn't the unit have demonstrated more trouble later in the ride?
Thanks again,
Edit to add total 61km ride file patched together with gps merged to get good timestamps.
Thanks again,
- iBike_08_04_2012_1617_61_km_N Loop_eFrancis ib8.ibr
- (1.01 MiB) Downloaded 431 times
