I had part of a ride missing cadence due to the sensor moving.
When I tried to do the correct function in Isaac software, the Powertap power remained zero
Can this be added to the list.
Failure to correct for missing cadence?
travispape
- Site Admin
Re: Failure to correct for missing cadence?
Send us your ride file(s) and a bit more explanation if you like. I'm not sure if I understand the issue.
Just slide magnet down the crank arm so the cadence sensor can't pick it up
Here is the ride file--powertap data does not show even after "repair for missing cadence" is chosen
- iBike_07_02_2012_1442_3_Miles.ibr
- (32.53 KiB) Downloaded 394 times
