Newton Instructions, FW 4 and prior
Detailed iBike Newton Instructions for Newton FW 4 and prior, updated August 9, 2014. Detailed Index of Topics has been added at the end of the document.
Newton QuickStart document120313.pdf
QuickStart Installation Summary Instructions
(227.35 KiB) Downloaded 438 times
Newton Instructions Indexed080914_red copy.pdf
Newton Instructions FW 4.xx
(634.64 KiB) Downloaded 435 times
Re: iBike Newton Installation and Usage Instructions
To do a hard reset, press-hold the bottom, right, left, and center keys simultaneously.
talaskgg
Post by talaskgg »
My Newton will not leave the setup page. Depressing the top key while in it causes the words setup to appear again.
talaskgg wrote:My Newton will not leave the setup page. Depressing the top key while in it causes the words setup to appear again.
Please do a hard reset and see if that fixes the problem.
talaskgg
Post by talaskgg »
Yes, a hard reset did the trick
tdriscoll
Post by tdriscoll »
I am at my wit's end... I have entered basic information (i.e. weight, height, alt, etc.) and completed the "tilt"; however, I am unable to complete the scan. The only item that will scan is my Garmin heart rate belt. Does anyone have any suggestions? I keep on getting a "Speed Error" message. Enclosed, please find three pics. Pic # 1 shows "Cadence Set-up Option # 1. Pic # 2 shows "Speed Magnet to Magnet Set-up" and Pic # 3 shows "Cadence Set-up Option" # 2.
The spoke magnet needs to pass within 1-2 coin widths of the vertical notch in the rectangular speed sensor. It's unclear from your photos if this is the case.
Please give us a call and we will help you sort things out.
ronpei
Post by ronpei »
one small edit I have seen so far, on page 22 the step 7 is missing the word tilt inside the quotes.
ronpei wrote:one small edit I have seen so far, on page 22 the step 7 is missing the word tilt inside the quotes.
Got it!
Return to “Installation/Usage Instructions and Videos”
