iBike Powerhouse: Restart a program?
merneric
Post by merneric »
Hello again!
We've been using iBike Powerhouse, but wanted to synch our workouts together. Is there an easier way to re-start a program (i.e. iSlim) over from the beginning? The only way I could manage to do it was to actually uninstall the app and then reinstall to start over fresh.
Re: iBike Powerhouse: Restart a program?
Tap the "i" button at the top right of the plan. Then tap Plan Progress. After a few minutes you'll see your entire plan progress on a calendar. Scroll to the bottom; there is a red button where you can restart the plan.
FelicianoVASA
Post by FelicianoVASA »
The "I" panel in blank. How can I fix that?
Here are screen shots showing you what to do
1) Touch the "i" button at the top right of the main window
2) Touch the "Plan Progress" tab in the window. It may take a while to change to Plan Progress
3) Scroll to the bottom of the Plan Progress window
4) Touch the red "Delete Workout" button
"i" button at top right of window
Last Ride
Last Ride
Plan Progress
Plan Progress
Delete Workout
Delete Workout
