Hello,
I noticed that while riding today that the power readings are zeroed out but when I upload the file to iBike software it shows power levels at normal range (about 250). The app software I'm using is:
App Software: 1.0.13
Hardware: 2.0.1
Firmware: 1.2.18
iDash+Power
Is there anything I can do to get this working again?
iDash not showing Power readings
Keep on Pedaling,
Ray Garza
Ray Garza
Re: iDash not showing Power readings
Attached is a simple 2 mile ride that showed no power output on the iPhone but when imported to iBike software power shows up.
- iDash_2012_04_15_1852_2_mi.ibd
- 2 mile ride with no power readings on iDash but shows up in iBike mac software
- (13.95 KiB) Downloaded 445 times
Something seems seriously wrong with your wind readings and your tilt calibration...
Please do another complete bike setup, and retry.
- peculiar wind
- Screen Shot 2012-04-16 at 3.56.28 PM.png (52.59 KiB) Viewed 6169 times
- bad tilt
- Screen Shot 2012-04-16 at 3.58.36 PM.png (33.87 KiB) Viewed 6169 times
ok will do and will let you know the results. Thanks for suggestion.
Keep on Pedaling,
Ray Garza
Ray Garza
I did a full setup including tilt and wind zero. Rode out to where I was going to do my calibration ride and my power readings came back. Did the calibration ride and rode back home. I uploaded the ride back home. Seems to be back to normal. Can you check and see if I'm good to go?
Also, Can you explain what you do with the file? Is it something I can learn to do? Would be nice to do the analysis first before I contact y'all for help.
- iDash_2012_04_16_1839_2_mi.ibd
- ride after full setup and calibration ride
- (17.27 KiB) Downloaded 420 times
Keep on Pedaling,
Ray Garza
Ray Garza
