I've just brought a new bike and moved my iPro onto it, and it now sits slightly higher than on my old bike.
I've done a cali and coast down test.
However, my power reading when on the flat or going downhill are not correct. In fact today, when I was on a 0.03% decline I had watts of around 170.
This only happens when I am pedaling though, not if I'm coasting.
I do all the usual set up techniques and have stopped mid ride to do them again.
I've got latest firmware 4.26 and cant see what else I can do. The iPro is nearly 2 years old
Anyone have any ideas why, or what I can do to resolve the problem.
Rob
Power Reading too High on iPro
Re: Power Reading too High on iPro
Ride file attached
Hope its what you require
thanks
thanks
- iBike_04_08_2012_1005_48_km.csv
- Ride file 8/4/2012
- (316.81 KiB) Downloaded 453 times
This is the data from todays recovery ride which has an RPE of 5, as you can see the power, TSS, NP is way too high
Dist: 23.2 km (0:57:50)
Energy: 619.5 kJ
Cals Burn: 592.3 kcal
Climbing: 221 m
Braking: -50.3 kJ (-8.1%)
Min Avg Max
Power 0 178.5 563 W
Aero 0 53.2 298 W
Rolling 22 105.4 211 W
Gravity -798 1.8 464 W
Speed 5.0 24.0 48.1 km/h
Wind 0.0 24.6 49.2 km/h
Elev 28 58 101 m
Slope -17.0 0.03 13.0 %
Caden 1 86.9 118 rpm
HR 62 129.1 163 bpm
NP:227W IF:0.95 TSS:86 VI:1.27
CdA: 0.240 m^2; Crr: 0.0190
85 kg; 13/04/2012 12:14
16 degC; 1007 mbar
Energy: 619.5 kJ
Climbing: 221 m
Min Avg Max
Power 0 178.5 563 W
Aero 0 53.2 298 W
Elev 28 58 101 m
HR 62 129.1 163 bpm
16 degC; 1007 mbar
In the ride file you submitted there is no wind speed data whatsoever.
Please repost file, preferably in .ibr format (as downloaded).
Hi John
Here is .irb format
just on another problem, my compute keeps (about every 5km) resetting itself i.e it stops picking up cadence/speed and HR and then scans to pick them up.
thanks
Rob
Here is .irb format
thanks
Rob
- iBike_04_08_2012_1005_48_km.ibr
- (105.95 KiB) Downloaded 482 times
