Print out question
PAllen
Print out question
Post by PAllen »
Any clue why the yellow appears on my printout (pdf attached)? It started several releases ago.
I'm using an iMac with an HP C8180 printer. It's just annoying.
Paul
iBike for Mac.pdf
(473.39 KiB) Downloaded 524 times
Re: Print out question
Well, I've never seen this before...
Tell us more about your iMac and iOS.
PAllen
Post by PAllen »
Here's the info... I can't remember exactly when this started but it's been a while. It's also strange that the yellow shows on the PDF and Preview.
Paul
Model Name: iMac
Model Identifier: iMac9,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.93 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 6 MB
Memory: 4 GB
System Version: Mac OS X 10.6.8 (10K549)
Kernel Version: Darwin 10.8.0
Boot Volume: Macintosh HD
Boot Mode: Normal
Secure Virtual Memory: Not Enabled
64-bit Kernel and Extensions: No
HP LightScribe:
Status: Stopped
Print Server: Local
Driver Version: 1.0.0.001
Default: No
URI: lsbackend://printer
PPD: LightScribe
PPD File Version: 1.0.0.001
PostScript Version: (3010.107) 0
CUPS Version: 1.4.7 (cups-218.31)
Fax support: No
Scanning support: No
Scanning app: -
Scanning app (bundleID path): -
Scanner UUID: -
HP Photosmart C8100 series:
Status: Idle
Print Server: Local
Driver Version: 4.3.1
Default: Yes
URI: usb://HP/Photosmart%20C8100%20series?serial=MY84LG10JT04YH
PPD: HP Photosmart C8100 series
PPD File Version: 4.3.1
PostScript Version: (3011.104) 0
Fax support: No
Scanning support: Yes
And which version of iBike software?
PAllen
Post by PAllen »
ver 6.1.1. I use both a Gen III iPro and the iDash.
One more question: when you print out your images, what is the specific procedure you are using?
OK, I was just able to reproduce this bug on my Mac.
We will investigate... :-)
PAllen
Post by PAllen »
Thanks, you guys are great!
Paul
travispape
Site Admin
Post by travispape »
I have looked into this bug and can repeat the problem. Unfortunately, this is a bug related to the development system and is not something that I can fix easily, nor are there any workarounds that would not be massive undertakings.
I have reported the bug to the makers of the development system and they are working on it without promising a date for a solution.
Note that in the mean time you get better results by using screenshots: http://guides.macrumors.com/Taking_Scre ... n_Mac_OS_X
Travis
