I assume it is pretty easy to take the mount off if you don't want to use it.
But if you remount it I am guessing one would need to do another calibration ride?
I assume you don't if you are just replacing the recharged battery...
When remounting, do you need to re-cal?
ScottChapman
Re: When remounting, do you need to re-cal?
No need to do a calibration ride assuming you're not making any changes. You can remove it and re-install at will.
