Pretty crazy ride data
ScottChapman
Looks like my tilt was all over the place here. Any ideas what might cause this? First time I have ever seen anything like it.
- iBike_08_02_2011_1124_21_Miles.csv
- (767.81 KiB) Downloaded 496 times
Re: Pretty crazy ride data
Wow! I think the indicator is the grey areas in the Analyze routes view indicates something loose in the headset area. Did you recently make an adjustment or have work done?
If this unit is out on the handlebar, also check the stem to fork and stem to handlebar tightness.
ScottChapman
Nope, no work done. Headset still nice and tight.
Besides, if it were just a tad loose I might expect small changes, not those HUGE jumps.
Can you do a tilt calibration to see if the unit responds properly and do the tilt numbers seem right? Do you recall seeing any tilt numbers during the ride? You should have seen massive wattage based on the tilt recorded.
ScottChapman
Did an 80 miles ride today and everything was fine.
Very odd eh?
Very odd eh?
