are there instructions or video to assit with the cadence sensor? I have screwed the magnet on the wheel and attached with tie wraps the sensor on the bottom of frame; I am not getting any reading on the dash.
Any suggestions?
Regards, Hugh Pope
install question: cadence sensor
- lorduintah
Re: install question: cadence sensor
The cadence sensor belongs on the frame and on magnet on the crank arm on the opposite side from the chain rings. (Left pedal arm)... The speed sensor belongs on the frame and magnet on the wheel. Do you have it set up this way?
If you are using a combined speed/cadence sensor, instructions are attached.
Combined Speed_Cadence_Sensor_red_Nov_10.pdf- (146.89 KiB) Downloaded 599 times
