Just completed a cal-ride with no coast downs. Used Profiles->Download Cal Rides and the software downloads the ride ok, BUT in the processing box the options to calculate/accept the profile are greyed out (see attached image)...
s/w: 5.1.1
Help?!
Mark
Did Cal-Ride but cannot send to device...
- Capture.JPG (117.12 KiB) Viewed 4109 times
Re: Did Cal-Ride but cannot send to device...
Since you did a cal-ride without coastdowns, the values of this cal-ride are already in the unit. If you have done you're fast Start setup then you're all set, if not you need to follow the screens for the Fast Start.
If you do more than one cal-ride, the results of the last cal-ride become your unit values.
To confirm this, connect your ibike and click on Profiles > Edit Profiles > Extract from iBike. This will show the values the combination of Fast Start and the cal-ride created as a profile.
Thanks, Fern, you are correct. Confusion came from the fact that on all previous calibrations I've done coast downs so expected to see processing.
Cheers,
Mark
Cheers,
Mark
