High watt readings while coasting
Bike4Him
Post by Bike4Him »
I have an iSport and have done many, many cal rides and coast downs, and e-mails to the iBike guys.
I've settled on a cal ride that seems to be good enough in the est fric and est aero numbers.
I believe I have things figured out pretty well. After 800+ miles I think it's consistent and hopefully accurate.
I am leary of the fact that many times the solution to issues discussed here seem to be tweaking settings via download.
With the iSport you cannot do the tweaks, but in my opinion, changing the info manually to get accurate results doesn't make sense.
All that being said I get readings while coasting downhill of 100+ many times. If I tap the brakes I can get it to zero but it will go back up.
On a 8%+ grade I can get readings of 300+ easy.
Tilt is correct
I zero the wind at the start and if the temp goes up.
I've got good cal ride and accurate info entered in set up.
Any thoughts.
Morocco Mole
Re: High watt readings while coasting
Post by Morocco Mole »
could you upload your profile, it's sounds like your CDA value is incorrect.
Bike4Him
Post by Bike4Him »
Morocco Mole wrote:could you upload your profile, it's sounds like your CDA value is incorrect.
It's an iSport. you cannot upload profiles or rides.
This is the part where I lose confidence because we would need to tweak input to get correct output.
Someone here said the iBike is a power estimator. It's more like a gateway PM.
Any other thoughts. I've got many rides coming up that involve long steep descents.
Any measurement device is only as good as its calibrations, and it is a fact that the iPro and iAero devices can be calibrated more precisely than the iSport, both because of the iBike software and because of the ability to perform multiple coast downs.
Coast downs are particularly tricky for the iSport, because you get only one coast down. With the Pro or Aero, you can do as many coast downs as you wish, then use the iBike software to analyze and improve.
I suggest you go into Racr sequence and reset Crr to 55. Then, do the Fast Start sequence, followed by a calibration ride. This will provide the best setup for your iSport.
If you want to try for more precise calibrations you should upgrade to the iPro.
Bike4Him
Post by Bike4Him »
Velocomp wrote:I suggest you go into Racr sequence and reset Crr to 55. Then, do the Fast Start sequence, followed by a calibration ride. This will provide the best setup for your iSport.
I have started to consider the cost / benefit.
The FriC screen shows 55. is that Crr
I believe I have a good calibration ride that followed a fast start sequence.
Bike4Him
Post by Bike4Him »
slightly off topic.
What is the total cost to upgrade and have all software necessary?
I like the iSport. I am hooked on training by power. I have a low budget.
Here is where to get details:
http://www.ibikesports.com/detail.aspx?ID=66
Bike4Him
Post by Bike4Him »
Bike4Him wrote:
Velocomp wrote: The FriC screen shows 55. is that Crr
