Free SportTracks no longer available?
Re: Free SportTracks no longer available?
SportTracks has been upgraded to 3.0. It's still free but with some limitations. You can only use two plugins at a time and there might be some advanced reports that aren't available. Go to the zonefivesoftware.com forum to download 3.0. It really is quite a bit better.
http://www.zonefivesoftware.com/sporttr ... ompare.php
Compare and click on the version you want. Grey button or green button.
Try it. The limitations are features not time IIRC.
You need to get on the ST forums. However, as long as you have the ST2 logbook, ST3 will open that logbook and then you can save it as an ST3.
Tommy, you really need to have this conversation in the SportTracks forum where either myself or any one of thousands of users are willing to help. I really don't remember the answer right now but I believe you just open the ST2 logbook, not import it.tommyturbo wrote:Fernando,
How exactly do I access the ST2 logbook? When I opened ST3 I had to create a new athlete profile. I tried to import my logbook, but ST3 does not recognize it. I can't import any new iBike files either, as it looks like ST3 is set up only for Garmin devices, and I can't figure out a way to import from the iBike.
still-chasing
In the options menu, click athlete and set your zones.
For Importing:
http://www.zonefivesoftware.com/sporttr ... s/?p=ibike
In ST3 Click Select View > Categories > Power and declare your zones.
Also, for detailed analysis
http://www.zonefivesoftware.com/sporttr ... g-analysis
- power_zones.jpg (38.66 KiB) Viewed 12982 times
Golden Cheetah Rules!
Anyone knows how to import Polar Files there?
