Changing ride data after ride when trainer mode was on
adrescher
Post by adrescher »
Hello all -
I see a feature to convert ride data from trainer mode to a ride, but it's grayed out in my software. Is there a way to change the ride data to be accurate when you did an outdoor ride in trainer mode by accident?
Andy
adrescher
Re: Changing ride data after ride when trainer mode was on
Post by adrescher »
More info - so looking at past rides that I know were trainer rides the option is not grayed out, leading me to believe that the software does not think that this ride was in trainer mode. Is that a correct assumption? Does the ibike know to switch off trainer mode if you are riding outside and it measures wind variations that would not be indicative of an indoor ride?
Please post a ride file.
adrescher
Post by adrescher »
Hi John -
It was one of my clients that had the issue and she had low batteries in addition to being in trainer mode. So her ride got chopped up and she only downloaded the file with the largest miles in the filename and deleted the rest. Turns out the miles were messed up in the file name and the miles were only 1.86 instead of 58 that she rode. So we talked about it. This is the file she sent me, but not sure it's worth anything at this point. We chalked it up to learning experience for her.
That being said, if the iBike recognizes wind speeds changing, will it automatically switch over to non-trainer mode?
Andy
iBike_01_15_2011_1302_58_Miles.csv
(98.94 KiB) Downloaded 357 times
