IPro re-mounting
madmaxx
IPro re-mounting
Post by madmaxx »
I wanted to re-locate the mounting of my IPro, i know that i would need to do a tilt calibration but do i still need to do another calibration ride considering i use a RWS?
Thanks...
Re: IPro re-mounting
Whenever the iPro is relocated, a new tilt cal should be done.
As long as the location of the RWS doesn't change, and no odd kinks are placed in the hose, there should be no reason to do a new Cal Ride.
madmaxx
Post by madmaxx »
Thanks...
bradwilson
Post by bradwilson »
I have re-located my iBike Pro and it is basically in the same position but tilted upward a little bit. The tilt has been re-done, should I do another Cal ride? I do not use the RWS, I am using the built in port.
If you move your position significantly you should do a new Cal Ride. The location of the iBike on the bike can affect significantly the stagnation pressure at the wind port, thus causing changes in wind sensitivity.
bradwilson
Awesome, thanks!
