iBike scanning SpdCad as one sensor
mirandag_01
I have 2 profiles for my iBike - TT and road. Both set up with wireless mounts and speed, cadence and heart rate sensors. The road bike set up works fine, however I often find that the tt bike scans for sensors and only picks up 2 -" hrt" and "spdcad". Then my iBike gives me zero readings for everything. It seems maybe it is picking up speed and cadence as one combined seonsor?? Do I need to move them??
Re: iBike scanning SpdCad as one sensor
No the signals are different. Are you possibly picking up somebody else's sensor? Why do you keep doing scans ? We send them from the factory already paired.
When doing a scan be sure there are not any active sensors with in 100 ft . If there are, you can try using your body as a shield, it will absorb the signal.
