Repeated SPD FAIL/SPD FOUND messages
rainer
Post by rainer »
During the last few weeks I'm experiencing problems with my wireless unit. Repeatedly, "SPD FAIL" flashes up, followed a moment later by "SPD FOUND" (after I pressed the center button). On a bad day, this can happen in 30-second intervals, but it surely happens once in 15 minutes.
- Batteries are fresh, of course.
- I did a hard reset (repeatedly) on the sensor, on the wireless unit, and on the ibike with no success.
- I moved the speed sensor to a different location in case my legs are blocking the signal. Now, it's 1,20 m away from the unit (on the rear wheel), with no obstacles in between. I do hear the clicking sound when the magnet passes by.
- No problems at all with the heart rate sensor. Heart rate is shown all the time, so it shouldn't be the wireless unit itself.
Can anybody help?
Cheers
Rainer
Re: Repeated SPD FAIL/SPD FOUND messages
Try changing the battery in your speed sensor. Insert backwards to do a hard reset, insert normally, then wave magnet past sensor to activate it. Wait 1 minute before pairing.
rainer
Post by rainer »
That's just what I did. I will try again and report what happens.
rainer
Post by rainer »
No, that didn't help. SPD FAIL again. Too bad.
Multimeter readings of the batteries: 3.08 V on the sensor, 2.97 V on the wireless unit.
gmc219
Post by gmc219 »
I have been having the same problem with my Gen III for about a month. I have been able to get it to work occasionally but this last time I can't get it to pair at all. It will say "speed found" then won't pair HR or Power then when say "SPD Fail" I have changed the batteries twice. I know my PM is transmitting because my Timex Gobal is picking it up. Appreciate any assistance.
gmc219
Post by gmc219 »
I was able to get mine working again. I put another new battery in, even though it said it was good. Winter time is coming, I guess I better order another pack of 50 batteries or so to get through the winter.
rainer
Post by rainer »
I finally solved the problem by moving the sensor to the front wheel. The signal seems to be too weak when coming from the rear wheel.
