I'm on a Mac (OS x 10.6.4) and I'm running version 4.9.0 of the iBike software...here is the error I get after the file is apparently downloaded:
Error 7 occurred at Open/Create/Replace File in iBF save iBike csv file.vi->iBIntf save file.vi->iBIntf process ride data.vi->iBIntf dialog download ride data.vi->iBIntf dyncall dialog download ride data.vi->iBike top-level VI.vi
Unfortunately the file only shows 76 of the 101 miles that I rode...what's going on?
Thanks in advance!
Delane
LabView error?
LabView error?
- capture 2010-09-12 at 8.29.45 PM.jpg (132.57 KiB) Viewed 7887 times
Re: LabView error?
I deleted and reinstalled the software....this seems to have caused more trouble. Here is the new error.
So I went to my iMac (older version of the iBike software since I'm too lazy, busy, to update and and it downloaded the file but again only 76 miles...
The unit is showing me 102 miles of date, averages, totals, etc.
Anyone have any ideas?
- capture 2010-09-12 at 9.15.38 PM.jpg (54.62 KiB) Viewed 7866 times
Re: LabView error?
Just wondering if anyone has any insight into this issue.
Thanks in advance!!!
Delane
Delane
travispape
- Site Admin
Re: LabView error?
Make sure you are using a valid download folder. You can set your download folder either under preferences or in the ride download window.dbrouse wrote:Error 7 occurred at Open/Create/Replace File in...
Regarding the VISA timeout error, the first thing to check is that you have set the com port in the "Device->Connect" window.
Travis
Re: LabView error?
Neither of those solutions worked. How can we tell is anything is wrong with the unit?
