Some power meters (e.g. Powertap) will transmit speed and cadence to Garmin ANT+ receivers (Edge 705/500).
Will the iBike transmit speed/cadence with its power info?
Specifically I have a Garmin GSC-10, but I have had speed dropout problems with my Edge 500 which do not appear in the iBike data.
See: https://forums.garmin.com/showpost.php? ... stcount=33
So one thought might be to use iBike power meter (re)transmitted speed/cadence.
If not, then I could see a need for non-Garmin ANT+ speed/cadence to be sent with the power information.
Does iAero transmit speed/cadence on ANT+ ?
- lorduintah
Re: Does iAero transmit speed/cadence on ANT+ ?
Have you installed the latest firmware on the Garmin? They have issued a few updates that may be intended for this kind of issue.
