I have updated the firmware and have done a hardware reset on my new iPro wireless, so i went to do a calibration ride, and after i got back, i got calibration fail message. I tried 3 times over the same course, one after each other and i got the same result, i re-did the tilt and wind offset, both successfully each time. However i cant get the calibration ride to pass.
Any Ideas?
Calibration Ride Failed
Re: Calibration Ride Failed
Can you post a solo ride on here where you started and ended at the same place? I want to see if maybe your wind scaling is out of the acceptable range.
sorry for the delay, have been realy busy with work. I have uploaded a 20km ride and one of the calibration rides
- iBike_06_28_2010_1910_20_km.csv
- 20Km ride
- (651.71 KiB) Downloaded 501 times
- iBike_06_23_2010_1032_3_km_CalRide.csv
- Failed Calibration ride
- (134.24 KiB) Downloaded 539 times
Something is wrong with your wind sensor readings and it needs to be looked at. Please send it to us.
Note that your iBike is nearly two years old.
Thanks for the reply, 2 things
- how do i get the wind sensor readings?
- i bought this from a bike store in june this year....
Dave
Dave
I have managed to get the calibration done and have done 10 cost downs, numbers seem to fit better. I checked the wind sensor and there was nothing stuck in there, i got some Air in a can and gave it a clean, Last nights ride showed wind reading that seemed more realistic, and it was the first ride that hasnt asked if i was drafting, when i never draft as i only ride solo.
Dave
Dave
