Calibration rides, which setting to use.
GWPOS
Post by GWPOS »
I have just one question..maybe. After completing a cal ride with coast downs then using the software to analyze the ride file which setting do we use to get the right profile numbers. "setting in IBike", "crr fixed" or "crr adjusted". My numbers are a little off on downhills and I used crr fixed, but if I change it to crr adjusted then I think my numbers come out a little better but my crr is low .0035.
I am already using one of these profiles I have but I am attaching 2 cal files and am wandering what my profile SHOULD look like to see if I did things right. Like I said if I use adjusted i think I get a more realistic or accurate CDA but a low crr. When using adjusted I get almost exactly the same CDA for both of the profiles.
100513_0701_cal_ride_AB7E100E.ibcd4m
(752.95 KiB) Downloaded 537 times
100514_0706_cal_ride_AB7E100E.ibcd4m
(768.23 KiB) Downloaded 498 times
FelicianoVASA
Re: Calibration rides, which setting to use.
Post by FelicianoVASA »
Hello,
I have done a new calibration but in the Isaac 2.3.0 the button that says Set Profile in Idash do not work.
I have select the Idash menu. How can I see the new data for the new profile?
Ibike Idash profile.jpg (87.59 KiB) Viewed 3679 times
