I realize this isn't the proper forum but I would rather post here in hopes that someone I "know" can help me with partitions that were accidently deleted from a RAID setup.
If so, please send me a PM or an email, fernando.j.maldonado at gmail.com Thanks a million.
OFF TOPIC HELP NEEDED
- lorduintah
Re: OFF TOPIC HELP NEEDED
PC or Mac?
What RAID level? Striped or Mirror? Sometimes the software used to install a RAID setup can be used for recovery, too - or contact the source of the software - assuming it is not a hardware RAID. OR check Google for help with the type of RAID you are using - and hoping you are not toast!
That's as much help as I can be.
Hi racerfern
I have had to use software to recover partitions and/or files after windows became corrupt. There are a few free ones but most of them will only let you recover files of a certain size, usually very small files at that. If you pay for the full version you can recover everything.
Not sure if this will help or not, but take a look at Acronis Disk Director - http://www.acronis.com/homecomputing/pr ... index.html
http://www.acronis.com/homecomputing/pr ... xpert.html
Other things that I've found
http://www.runtime.org/
http://www.ptdd.com/datarecovery/recover-raid-drive.htm
HTH,
Robert
HTH,
Robert
