I own 2 bikes. One has a wireless mount, the other the standard mount. Last week I had a mechanical with hte bike with wireless and switched the iBike to the bike withthe standard mount, so I switched off the wireless mode and off I went. It worked ok, except that I somehow lost my profile on the iBike and the stadnard one defaulted and caused some very low wattages. But when I went back to the wireless bike I found that my sensors were no longer "found" and I had to repeat the "finding" process (including the battery shorting thing). The question s shoud I anticipate that I will have to do this every time I switch the iBike between wireless and standard bikes? Or, was this just associated with the "lost" profile process?
Second, has anyone had a problem reloading 2_0_1? Somehow I lost my communications with th eiBike device and I have been unable to get it back. I got a message that says that the program will not add any files or some such and I can't make it work.
Glenn
Sensors and transfer between wireless and standard mounts
Site_Admin
- Site Admin
- Contact:
Re: Sensors and transfer between wireless and standard mounts
The profiles always save sensor pairing information, so you should've loaded your profile before riding. Now that you have a new pairing, you need to save that.talaskgg wrote:I own 2 bikes. One has a wireless mount, the other the standard mount. Last week I had a mechanical with hte bike with wireless and switched the iBike to the bike withthe standard mount, so I switched off the wireless mode and off I went. It worked ok, except that I somehow lost my profile on the iBike and the stadnard one defaulted and caused some very low wattages. But when I went back to the wireless bike I found that my sensors were no longer "found" and I had to repeat the "finding" process (including the battery shorting thing). The question s shoud I anticipate that I will have to do this every time I switch the iBike between wireless and standard bikes? Or, was this just associated with the "lost" profile process?
Glenn
It sounds like you've punched the tar baby (like others). Send me a private note and we'll schedule a tutoring session.
