menu map
cyberbillp
menu map
Post by cyberbillp »
Is there a menu map for the ibike?
There's usually a menu map stuck to the wall over the printer at work.
Here's an example of what I mean.
http://swm1.com/flying/FMA/Multi4/pictu ... u_flow.png
It would be a huge help.
Re: menu map
We're working on one...
cyberbillp
Re: menu map
Velocomp wrote:We're working on one...
To busy with the iphone to finish it?
KenS
Re: menu map
Post by KenS »
I made my own map by scrolling back and forth between the menu options. I did this because there are a couple of "easter eggs" in the menu which I always have trouble finding.
To get to the Abs Wind option you need to first get to Fit Test in the User menu then use the down/right arrow to get to Abs Wind. If you just use the up/left arrow you will never find it.
Likewise for the FTP cfg option you need to first get to Total hrs log in the Racr menu then use down/right arrow to get to FTP cfg. If you just use the up/left arrow you will never find it.
Not sure if this is a bug or a feature or maybe an aptitude test :)
-- Ken
Re: menu map
This is close to what many people have been looking for, though not identical to a screen map.
http://www.ibikeforum.com/viewtopic.php?f=12&t=1634
