Two questions on iBike-4
whftherb
Post by whftherb »
Hi -
I have a recent ride file that has a speed scale of 0 mph to 100 mph. This makes reading the results rather difficult. Is there a way to "re-scale" the speed graph on iBike-4 to something more in line with the norm, say 0 mphto 30 mph?
Any help appreciated.
H
Re: Two questions on iBike-4
You can double-click the upper value - in this case 100. It will be highlighted and you can then type in 30. The plot should re-scale.
If your scale is 0-100, then somewhere in your ride file is an erroneous speed data point. You can highlight the mischief maker by click-dragging over it, then edit it out with the File/Delete Selection... command.
