Attached are instructions that describe how to perform a wireless scan.
A new Scan is required whenever a wireless sensor battery is changed or whenever a new bike is set up.
Note that these instructions apply only to Gen III iBikes.
How to Perform a Wireless Scan with Gen III iBikes
Wireless Scan instructions_Summary_Feb_10.pdf- (87.15 KiB) Downloaded 1314 times
Re: How to Perform a Wireless Scan
I'm stumped how to do this. I hold down the top and bottom arrows at the same time (tried about 20 times) but it will never do a scan. Only ever goes into setup. I'm guessing this means I'm not quite pressing them right, but I just can't do it! Any other way to initiate a scan?
Gerrard
Gerrard
Go into setup and click the up arrow until you come to a screen that says "REL". What is the number beneath it? This is your firmware version.
Note that the Scan procedure works only with Gen III iBikes, with firmware 4.17 or higher installed.
Re: How to Perform a Wireless Scan with Gen III iBikes
Thanks John I thought I had upgraded the firmware but it was still only 3.x. Apologies for that. All good now.
