OK so I did my calibration ride then tried to download it on the iBike software but the program would not accept it. Tried it after restarting my computer same result then it wouldn't even find a calibration ride. I erased the unit of all rides ( indoor trainer rides) and plan on doing my outdoor calibration ride again. Any similar problems or suggestions?
Calibration ride not accepted
- lorduintah
Re: Calibration ride not accepted
Can indicate that the mount is not stable and slipping or that you have a bad tilt calibration or wind speed offset. Did you pass any cars during your ride - the gust of wind they can generate may set off the error flags for an analysis.
You might do a hard reset after checking that you have the latest firmware.
