Custom profile
bjrmd
Custom profile
Post by bjrmd »
Hi
Is there any way to make a more custom profile based on an old one. I have a powertap and by trial and error have found a good wind offset,cda, crr-friction to use. I can adjust the friction which then changes the crr--that seems ok. But if I adjust the cda, the wind offset changes--any way around this. And yes--I have done many calibrations--no single one gets it just right.
Re: Custom profile
Aero, CdA and Wind Scaling all play together. You can change CdA, then adjust Aero to get back the wind scaling or a combination of the three. Fric, Crr and Tilt have the same game plan. You just fiddle to what you want.
Re: Custom profile
bjrmd wrote:Hi
Rather than adjust the CdA, adjust the aero number to give you the CdA you want. That way the wind scaling isn't affected.
Re: Custom profile
I never paid enough attention to how the three were tied together in the software, just toggled each until I go what I was looking for. Thanks Fernando.
Re: Custom profile
Post by Russ »
CdA times Wind = Aero
Enter your wind
multiply CdA time wind
Enter the answer into Aero
your CdA should then appear
bjrmd
Re: Custom profile
Post by bjrmd »
Thank you
