speed not working
apond58
speed not working
Post by apond58 »
I changed the battery in my iSport and now the speed does not work. The sensor is about 3 mm from the magnet. Everything else works but no power numbers without speed. I've tried changing the battery etc. Battery power is around 285. Any suggestions?
coachboyd
Re: speed not working
Post by coachboyd »
Are you using the wireless sensors?
If so, go into wireless config and set the speed to find and see if that works.
apond58
Post by apond58 »
The unit is wired but I tried flipping the battery briefly (as suggested on one of the other posts about a different problem) and it seemed to get it going.
