Since loading the 3.09 firmware my tilt values are way off, resulting in incorrect power values. I can get a good tilt calibration but once I start riding I'm seeing crazy values like 65% grade. Once I see the bad numbers, the tilt is still wrong even when stopped. Intermittently it will just show zero watts.
Does it make sense that I need to do new cd's and cal ride? The batteries are all good.
Is the tilt impacted by the profile or is it reset each time I calibrate the tilt?
Not sure what else to do.
Tilt is way off
- lorduintah
Re: Tilt is way off
I had to do a hard reset a couple of times and at least it cleared up - no promises.
