Isaac installation on new laptop
Dutchbiker
Post by Dutchbiker »
I'm installing a new laptop. Does the new Isaac installation see the 2 profiles that are in the PPV3 or do I need to do new calibration rides.
Regards from the Netherlands Wim
Re: Isaac installation on new laptop
If you're installing Isaac on a new laptop, you can transfer your PPV3 profiles into Isaac. Do the following:
1) Connect V3 to Isaac
2) Go to Edit/Edit Profiles
3) Click "Get from Device" to get the active profile information. Isaac will tell you which profile is active
4) Click the "Set Active Profile" dropdown menu to select the other profile. Then click "Get from Device" to get your other profile
Dutchbiker
Velocomp wrote: Sun Nov 03, 2019 4:52 pm If you're installing Isaac on a new laptop, you can transfer your PPV3 profiles into Isaac. Do the following:
Thank you John for your swift reply. Kind regards
