AeroPod battery capacity
ted.kelly
Post by ted.kelly »
I think I read that the AeroPod can store about 26 hours of ride data.
Starting from a full charge how many hours of data recording will the battery give?
I think I read that after about 20 min of zero bike velocity AeroPod will close a ride file and go to "sleep".
I think I read that it takes more than 2 months for an AeroPod in sleep mode to run down its battery. Is that correct? Is that starting with a full charge?
Does turning AeroPod "off" (push button 5 times) reduce the battery drain more than leaving it "sleeping"?
Re: AeroPod battery capacity
1) Yes
2) We've never tested this, but it should be about 26 hours. Note that this assumes constant riding.
3) Yes
4) Yes, yes.
5) No; they are the same thing.
