upon connecting - no stored profiles in AP
michal
Post by michal »
Is this normal?
When connected to PC - all were blank.
Re: upon connecting - no stored profiles in AP
1) Connect AP to Isaac
2) Go to "Edit/Edit Profiles"
3) Click "Extract from Device". This will be the profile information for the profile active in your AP
4) Click the "Export" button. Export the profile to your desktop
5) Please post the profile to this thread.
We will figure out what is going on!
michal
Post by michal »
Done today; I tried to reset the unit, hope it helps.
Tomorrow I'll hit the boards of indoor velodrome - will try to calibrate again.
michal_szlezak_profiles_12112018.ibp
(460 Bytes) Downloaded 318 times
The profile you downloaded is the factory default profile. It does not have any of your rider information in it, and it does not have any of your sensor IDs. You will not be able to use this profile to calibrate your AP.
Please watch the video linked below. It will take you through the setup process. If you have any problems, please let us know where in the video you run into trouble!
https://youtu.be/198XSnl6gnA
michal
Post by michal »
the newest file - did the calib ride to the letter (hopefully) - but amazingly low readings for CdA...
profile_recent.ibp
(460 Bytes) Downloaded 311 times
michal wrote: Wed Nov 21, 2018 9:39 pm the newest file - did the calib ride to the letter (hopefully) - but amazingly low readings for CdA...profile_recent.ibp
Please post the .ibr ride file recorded AFTER your cal ride was completed.
