Trainer Mode Switch in Powerhouse
stuflowers
Post by stuflowers »
New Powerpod owner here.
Is there any way to switch trainer mode ON/OFF without having to connect to Isaac and are there plans to add this function to Powerhouse? I imagine there could be a simple toggle switch in the Powerhouse settings/profiles screen.
Re: Trainer Mode Switch in Powerhouse
Right now there is no way to turn trainer on/off except through Isaac.
We will investigate doing this through PowerHouse. This will require both a modification to PH app and to PowerPod firmware, so don't expect it soon... :-)
stuflowers
Ok thanks John. For me and I presume others who use the same bike on and off the trainer, this would be a very useful feature upgrade for Powerhouse. I guess that in the meantime I could create two identical profiles (one with trainer mode turned ON and another with it turned OFF) then use Powerhouse to toggle them?
That is a very practical workaround!
stuflowers
I am able to connect to phone via BLE, however when trying to save a profile from PH to PP I get the message "Something went wrong. Either PowerPod is disconnected or your PowerPod doesn't support profile feature"
I am trying to setup a profile for indoor trainer usage (same bike) and use Powerhouse to switch between the indoor and outdoor profiles. Any ideas?
Please email technicalsupport@velocomp.com for next steps
Kqaltas
Post by Kqaltas »
Any update about this request? it is quite tedious to have to connect my PC just to switch to indoor trainer mode
Kqaltas wrote:
Mon Sep 09, 2019 8:36 pm
Trainer mode support in PH will have to wait for the next app update.
