700 x 30 tires
thejr
700 x 30 tires
Post by thejr »
Hi Powerpoders!
I notice this is not an option in the bike settings in Isaac or Powerhouse. My tires are 700x30c - what's the recommended value to use instead?
PaulK32
Re: 700 x 30 tires
Post by PaulK32 »
You can give 2136mm under "Measured" in Isaac for this profile.
Re: 700 x 30 tires
If you are using a bike computer that can estimate tire circumference from revolutions and distance (from GPS) - like Garmin Edge systems - they can report the value that you can use, too.
thejr
Re: 700 x 30 tires
Post by thejr »
Thanks both for the direction and suggestions - yes i think the Garmin speed sensor does this so will check that out.
