no watt shown on garmin 1030
Hjorth
Post by Hjorth »
I have make a full out and back ride. After that i can see slop and wind numbers on my Garmin, but no watt. In the my date felt is standing - 0 watt. Powerpod is connected to garmin edge
What have I done not wrong . :?
Re: no watt shown on garmin 1030
It sounds like you are using our ConnectIQ app. That's fine...
Slope and wind are transmitted on a different channel, compared to power.
If you haven't correctly paired PP to your Garmin, you won't see power.
Do the following:
1) Wake up the speed and other sensors on your bike
2) Confirm they are working by spinning the wheel, and confirming non-zero speed in the Garmin window
3) Wake up PP. If the light shows solid green, that means PP is paired to your speed sensor. Skip to step 5
4) If light does not flash solid green, do another sensor pairing between PP and speed sensor. At the end of a successful pairing, light will turn solid green, then go out.
5) Once you have confirmed that PP is paired to your speed sensor, pair PP to your Garmin. Your Garmin should show that it is paired to a power sensor.
Once Garmin is paired to PP power sensor, you should see power in the app window.
NOTE: if you did a new sensor pairing (step 4) then you will also need to do a new cal ride.
Hjorth
Post by Hjorth »
Tanks for your help.
I have done all what you say. But it don't help
Alle look as you write . I do a calibration out and back. I see number from 0 to 100 on garmin edge. When I ride after that, the data feld shows the number 0. It shows 0 and not just -
I have restartet powerpod, hold in on/off 15 sek, before call.
Sorry to ask for help again and for my poor English
Uninstall the ConnectIQ app, then reinstall it, then set up the fields again.
