I have a PowerPod V4, Garmin Fenix 6 and two bikes with a Garmin speed sensor on each.
I'm trying to understand if I need to plug the PP into Issac and change profile manually when I move between bikes. DC Rainmaker in his review says it auto changes but I can't find anything in the documentation that says that happens. Could someone confirm if it does auto change profiles when it detects the speed sensor that is active?
Mike
Changing of Profiles
Re: Changing of Profiles
Confirmed.
If you have two separate profiles, one for each bike, and you use different speed sensors on each bike, then PP will automatically switch between profiles when you move from bike to bike. Just make sure that when you move PP, that the sensor on your other bike is off; alternatively, awaken PP when you're about 100 feet away from your other bike.
Many thanks for the quick reply.
Cheers
Mike
Cheers
Mike
