Setting active profile with 2 bikes.
flysplat
Post by flysplat »
I have 2 profiles set up using profile 1 and profile 3. Here's what the Isaac screen for Set Active Profile in Device looks like.
1: Cube extracted on 16/08/2020 Prof '1
2: Unsaved (type Initial Setup
3: Forme exForme Tweaked 23/12/201
4: Unsaved (type: O&B Tweak
Profile 1 has been working ok all summer and now I want to use profile 3 which worked ok earlier in the year.
When I set profile 3 as active it works and sends readings to my Garmin computer but if I stop my bike the Powerpod reverts to profile 1.
I have tried changing the profile from 1 to 3 on a few occasions but get the same problem each time.
Has anyone got any ideas?
Re: Setting active profile with 2 bikes.
Are you using the same sensors on both bikes?
Please extract your profiles using Isaac, and post them here.
flysplat
Post by flysplat »
No John, different sensors on each bike.
The Cube works fine, it's the Forme that drops out.
Here is my last Cube ride and the Forme bike ride until I stopped and it then dropped out.3
cube.ibp
(603 Bytes) Downloaded 304 times
forme.ibp
(575 Bytes) Downloaded 325 times
Yes, you have different wireless IDs, which is good.
Question: when you stop riding and then resume, how do you know your device reverts to a different profile?
flysplat
Post by flysplat »
It was an assumption really because there was no power readout to my to my Garmin when I resumed the ride after a 5 minute stop. When I got home and plugged it into Isaac it showed profile 1 active rather than profile 3.
Profile 1 still works on my Cube bike so how about me deleting profile 3 from Powerpod, reloading it and doing an out & back ride on my Forme bike using profile 3?
flysplat
Post by flysplat »
Don't take any further action at the moment John - I''m trying another permutation of setting profile and doing a ride.
I'll report back.
