How to enable sensor under Profile edit ?
Kcblair
Post by Kcblair »
Hello John,
I use the same cadence and HR sensor on all bikes. After recalibration, , some profiles did not get the HR and/or HR sensor paired. So I added the ID and type, resent the profile to the PP.
Is there a way to enable those sensors, without having to re-pair and cause a calibration ride ? If not , not a big deal as that data is contained in my Garmin.
Thank you so much.
Ken B.
Re: How to enable sensor under Profile edit ?
If you have a profile which has all the correct IDs, then copy that profile into your other ones. Post out-and-back ride files from your other profiles and I will correct them for you.
There is no longer an easy way to type-in sensor IDs to your profile; Garmin uses 6 digits (I think) and we show only 5 digits in Isaac.
Kcblair
Post by Kcblair »
Thanks John, sounds easy enough .
Ken B.
