New PP Calibration
barnabeflores
New PP Calibration
Hello, I just bought a new PP V2 and updated with the latest firmware.
I loaded the following data in to the Isaac software:
- rider weight: 73kg
- bike weight: 10 kg
Did the out and back calibration ride. I post here the following ride and would like to know if it is OK.
Best regards.
Best regards.
- iBike_11_17_2018_0601_57_Miles.ibr
- (650.69 KiB) Downloaded 286 times
Re: New PP Calibration
Everything looks fine!
There appears to be a strong headwind on your return leg. Since you did a very long ride, it is entirely possible that wind conditions changed during the ride.
barnabeflores
Yes, there was a strong wind on my way back.
I didn´t feel it was that strong during the cal. process, but was concerned it could have messed up things.
Thanks and have a nice weekend.
B
B
barnabeflores
Hi again,
Last week I paired PP to another bike (and sensors), but today when I returned to the first bike the PP didn´t recognize the sensors. I pressed PP after all the sensors were paired with the Garmin and the light was a steady red. Tried it a few more times and the same happened. I had to do another cal ride.
Is this normal?
B
PS - I have the 641 firmware in PP
Is this normal?
B
Please do the following:
1) Connect PP to Isaac
2) Go to Edit/Edit Profiles/Extract from Device.
3) Export this profile and post it in the thread
If you are using more than one bike, have you created a separate profile for each? If so, please repeat steps 1 through 3 for the other profile. Please mark clearly which profile is which!
barnabeflores
Hi again John.
Here is the file.
I would like to change the calibration weight to 83kg. Should I do: Edit profile/ Advanced/ change the weight/Accept/ Send to device?
Best regards.
B
Here is the file.
Best regards.
B
- Bike n.1 profile.ibp
- (431 Bytes) Downloaded 240 times
Do you have a separate profile for each bike (for example, bike 1 is profile 1; bike 2 is profile 2)?
If you do not have separate profiles, then you should make them! This way you won't have to recalibrate every time you switch bikes.
barnabeflores
These are my doubts using the 641 firmware:
1 - Can I do what I mentioned in my last post to change settings in the same profile (ex. if I loose weight);
2 - To add another profile/ bike do I press PP for 4 sec to do an OB ride with the new bike/ sensors and then extract the ride from PP or,
2.1 - Do I previously create a profile using Isaac, send it to PP, do the OB ride and then extract the file?
B
B
You will use Isaac to set up a new profile:
2) Go to Device/Device Setup
3) Note the profile that your PP is using currently (probably profile 1)
4) Select a new profile (I suggest profile 2, but any profile is OK)
5) Follow the screens to enter the parameters for bike 2
6) After exiting the profile for bike 2, pair sensors for bike to to PP (MAKE SURE YOU ARE 100 FT AWAY FROM BIKE 1 SENSORS)
7) Do a calibration ride for bike 1
You will now have profile 1 for bike 1, and profile 2 for bike 2. Assuming that you are using different speed sensors for bike 1 and 2, PP will automatically switch between them.
barnabeflores
Got it John
Thanks for your time and help.
B
B
