Calibration check and profiles in PP
albafar
Post by albafar »
I just switched to a rear disc on my TT. It's been a while since I rode this bike the last time so I started out with a calibration ride. Then did a 10K right after. Does everything look correct or should I tweak some of the values?
Another question: It appears as if I can only have one profile in the PowerPod suddenly. If I try to transfer a profile it kind of overwrites the previous profile. In this case the TT profile overwrites the road bike profile and then there are 3 empty profiles. I'm certain I'm doing something wrong but cannot figure out what... :oops:
iBike_09_03_2018_0009_10_km_HiDef.ibr
(190.44 KiB) Downloaded 302 times
Re: Calibration check and profiles in PP
You are a strong cyclist! Ride file looks fine.
It sounds like you are missing an important step in the profiles.
1) Connect PP to Isaac
2) Open Edit/Edit Profiles
3) *I THINK THIS IS THE STEP YOU ARE MISSING*: Use the "Set Active Profile in Device" dropdown menu to set the profile where you want to transfer the profile
4) Select the profile you want to transfer, then click the "Send to Device" button
albafar
Post by albafar »
Thank you for the hint John -it worked. And thank you for your kind words - there are still more power to be build though ;-)
