Top Tip for charging your PP
mejulie69
Post by mejulie69 »
This is not a question, just a top tip I wanted to share ..... the is no need to remove your PP from your bike every time you need to charge it... equally, you don't need a power socket near by... just get yourself a powerbank / USB battery.
:D :D :D
posh
Re: Top Tip for charging your PP
Post by posh »
that is what i did using powerbank..... :D
viniga
Post by viniga »
Yup, good one, I've done this too.
4speed
Post by 4speed »
interesting tip, i made a inox plate to fix the meter (sorry for my bad english, see pictures)
Interesting idea!
posh
Post by posh »
:roll: what does it do?
viniga
Post by viniga »
Does that keep it at the same angle each time?
4speed
Post by 4speed »
Here the other pictures with some homemade parts
flahutewannabe
Post by flahutewannabe »
Nice work, @4speed! You have some machining skills way beyond mine... :lol:
I'm interested in the purpose of the clip over the Powerpod tab. Is it to prevent wear on the plastic tab, or to insure a solid connection to the mount? I could see where one could make a clip that would allow the mount to be tilted to optimize viewing the Garmin screen while still keeping the Powerpod at the appropriate angle. I find that I have to run my Garmin flatter than I'd prefer to keep the Powerpod as parallel to the ground as possible.
