Just finished a calibration and a quick out and back ride on the TT bike after getting a second speed sensor. The out and back ride is attached. Oddly no 'cal' file was recorded. This was using the latest firmware. Can you check this calibration please? I note that the check calibration feature suggests a 'noticeable change'.
Should I be concerned that there was no 'cal' file?
And just to check, each bike now has a different speed sensor, so when riding PP will switch profile automatically, correct?
Many thanks for your support,
Vince
TT Bike Calibration
TT Bike Calibration
- outnbacktt_07_18_2018_2045_8_km_HiDef.ibr
- (180.08 KiB) Downloaded 265 times
Re: TT Bike Calibration
Your file is close to perfect!
As the latest firmware notes state, with FW 640 we have eliminated the "cal ride" file. It is not needed.
If your different bikes have different speed sensors, when you switch bikes PP should automatically change profiles.
Thanks John.
So I should I ignore the suggested change in the 'Check Calibration' feature?
Check calibration is intended for short, out-and-back routes. I would ignore it for this ride file.
