Use DFPM cadence data
TuRu00
Post by TuRu00 »
Hello!
Is there any way on PP to use the DFPM cadence data in order to do not install another additional sensor?
Thank you!
Re: Use DFPM cadence data
If your DFPM has cadence in it, PP will "see" the DFPM cadence automatically whenever the DFPM is paired to PP.
Of course, you'll still need a speed sensor...
TuRu00
Post by TuRu00 »
Thank you! And on this case, what is the best valué for powerstroke? Below or above the chainstay?
Above
TuRu00
Post by TuRu00 »
Las question. Using magnetless cadence sensor is “above” aswell? Thank you!
Yes
