sporadic and excessive power peaks
pedrogallo
Hello John I think something is failing and I promise you that I do not hit the device because those changes of power and I still think that it measures erroneous in the ascent less power when the profile changes sure that with your dedication I will get it thanks today's tour in
- PedroGallo_19_05_2018_0846_86_El Pozo_Pezuela_km.ibr
- (954.25 KiB) Downloaded 286 times
Re: sporadic and excessive power peaks
You are seeing high watts on the downhills.
It looks like this was a group ride; is this correct?
There is a watt spike at mile 47.2. You are traveling at 45 mph and your cadence is 150...these are huge numbers!
At high speeds, any change in ride position can cause HUGE changes in watts.
I suspect this is what is going on with your ride.
pedrogallo
Re: picos de fuerza excesiva y esporádicos
Soy humano no una moto dime que ocurre si te das cuenta los picos los da al inicio y si en una bajada pero son erróneos porque esa es la pregunta que no consigo entender
