Morning,
I did a Best Accuracy calibration on my MTB bike and after that I did a short ride but I have the feeling the the power numbers are too high. Could you please check my calibration to see if there is anything wrong there?
Meste
MTB Calibration - good or bad?
Re: MTB Calibration - good or bad?
Please post your ride after your calibration. It is the best one to check for performance.
Aha, I did not know that, here it is attached. Thanks
Your Crr is a bit high, but everything else is great!
Load this into your PP and you should be good to go.
- Meste.ibp
- (415 Bytes) Downloaded 315 times
How exactly do I load it?
AHA, I think I know, through Edit Profiles I import the file you attached then send to device, right?
Correctmeste wrote:Hi John,
