High power when I started.
wildbiker
Post by wildbiker »
Hello.
I used PP very efficiently.
A few weeks ago PP showed high power beginning of riding.
By the way, 5 to 10 minuates later PP shows correct power.
So I checked the riding log, There was a error of slope grade.
Even It was a flat course but the log showed 8 percent slope.
I did a cal ride again.
But it occurs same.
How can I fix it?
Re: High power when I started.
You need to position your PP in identically the same angle whenever you attach it to your mount.
Whenever your PP is attached at a different angle, it will take 8 minutes for it to readjust itself.
Here is how to prevent that problem:
1) Slide PP into its mount
2) Loosely attach the GoPro screw
3) Push down gently on the top of the PP, near its button, until the PP hits the stop located in the mount
4) Tighten the GoPro screw so that PP is solidly attached and cannot rotate even when you nudge it
If you do these steps you should get consistent results every ride, even during the first 8 minutes.
wildbiker
Post by wildbiker »
You are amazing!!
